Selectively enables SNMPv3 default-group access on the switch.
| default-group | Specifies SNMPv3 default-group. |
Enabled.
This command is used to enable SNMPv3 default-group access.
Enabling SNMPv3 default-group access activates the access to an SNMPv3 default-group and the user-created SNMPv3-user part of default-group. This command produces an error if SNMPv3 access is disabled on the switch.
The default groups are: admin, initial, v1v2c_ro, v1v2c_rw.
The following command enables the default group access on the switch:
enable snmp default-group
This command was available in ExtremeXOS 12.2.
It was also included in ExtremeXOS 11.6.4 and ExtremeXOS 12.1.2.
The default-user option was removed in ExtremeXOS 22.1.
